Entry step interchangable with the Boondock
Kathestar
Member Posts: 1
We have a 2022 T@B 400. Can we replace the entrance step with the wider Boondock step?
I have the same question. The originated is too narrow to be safe for size 12 shoes!0
Figured I would put this here regarding step. We noticed the step was extended couple of times while going down the road.
i found they used lock washers and standard nuts which worked loose, I tightened them down and will replace with nylon lock nuts when we get back.2023 Tab 400 BD
2023 Ram 1500 crew cab0 -
Mine on my 2021 Boondock Step were all loose. Poor design. If I remember, I replaced six. NuCamp won't claim any responsibility. Their answer was "We don't make the step".
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
While on the surface not a big deal, I would think they mounted the steps and it rolled out of their factory so ultimately they are responsible.2023 Tab 400 BD
