Alde heater leak question
Finchy
Member Posts: 41
The Alde has been pretty solid in my 2014 T@B but after arriving at my campsite this last weekend, I noticed liquid in the rear passenger compartment next to the door. I don't see any leakage in the tubing , but the aluminum radiator seems to be leaking. I don't see where else it would be coming from. I also can't tell where the leak is coming from in the radiator exactly. Some pictures enclosed. Does anyone else have experience with this? It doesn't look one bit corroded?
Thanks!
Thanks!
2019 Tacoma Off Road
2014 T@B S Wet Bath Max Plus
Whenever you find yourself on the side of the majority, it is time to reform (or pause and reflect).
-Mark Twain
-Mark Twain
Liquid? Water or glycol?2015 T@b S Max white with silver trim. 2018 GC Trailhawk.0
Was it glycol or water? The wheel wells have been known to leak.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
water/glycol...definitely wasn't the wheel wells...glycol reservoir is drained2019 Tacoma Off Road
-Mark Twain0
