Custom Cushions
Basil48192
Member Posts: 444
I have a 2021 320S...and love my camper. I boondock camp alone a lot, but do get out with my wife quite often as well. In both cases, I/we like the twin bed set-up.
I know there are a lot of posts regarding twin bed modifications, but I'm not sure I've seen anyone that has replaced the original bottom cushion with a single, wider cushion.
Being a 2021, I can just pull out the sliding platform to any width (30" seems about right to me). However, instead of filling the resulting gap with a second, narrow cushion....I'd prefer to use a single, 30" wide cushion that I could leave in place while traveling with my wife.
I'd like to get two, bottom cushions: 30" deep x 32" long (standard length).
I will check with Nucamp to see if I can purchase 'customized' cushions from them. I am also going to try a marine supplier near my home. In case I strike out, does anyone have any experience with custom cushions on-line or otherwise? If possible, I'd actually prefer a faux leather material that would be more resistant to water and staining.
Thank you in advance!
Hi,
i I bought replacement cushions for my ‘21 from here. https://www.thefoamfactory.com/I bought the Lux Foam; High Quality with the Dacron wrap.2025 360 CS
Southern Maryland0 -
@Yoshi_TAB. Thank you! I am also looking for new covers...but may attempt to make them myself.
We sleep front to back with our feet under the cabinets in our '21 320S. The twin beds are great. We chopped up a wall cushion on our 2021 320S. Gives me a 32" wide by 78" long solo bed which is made up all the time (so I don't need any wall cushions on that side) and a 25" wide twin on the other side when we're both camping with a 14" wide isle down the middle. No more climbing over each other and easy to get in and out of bed without disturbing the other. We have 3" thick memory foam camping pads (32" and 25" wide x 75") we use on each side over the cushions that we roll up under the cabinets when not being used.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
How did you attach your Laguna table upright on the end?0
It just slides into the post vertically and the lower edge sits on the edge of the wood bench and overlaps the door frame. More info (scroll down): https://teardropsandtinycampers.com/sj-mods.htmtnmikewalker said:How did you attach your Laguna table upright on the end?
2025 Ford Ranger
Outdoor Fabric Central out of Florida makes custom cushions and covers. I never have used them for this service, as I do it for myself, but do buy Sunbrella fabric and supplies from them. They are very good to work with. You could also check Sailrite.2023 T@B 400 Boondock
2024 Jeep Grand Cherokee 4xe Trailhawk
2021 T@B 400
2019 Subaru Ascent0
