Front Window of t@b Hinge Broken
Hops
Member Posts: 53
There are photos with this post.
Have others had this problem?
Asking for advice, comments, possible DIY fix.
I have a 2017 320S. The plastic hinge piece on the front window has cracked and doesn't hold the window in securely anymore. I am told I need a whole new window as a replacement plastic piece is not available. Perhaps someone sells a replacement hinge(I've seen the galley hinge sold).
Please review the photos and offer any suggestions or input.
Hops and Cascade
2017 T@B 320 Max S
2014 Ford Escape 2.0 EcoBoost
2017 T@B 320 Max S
By the way..I can still prop my window up, but it falls out of the hinge easily.Hops and Cascade
2017 T@B 320 Max S
2014 Ford Escape 2.0 EcoBoost0 -
Thank you for participating in the discussion and the problems with the plastic hinge piece failing. So, I gather you reached your whole windows and not just the hinge. Is that correct,?Hops and Cascade
2017 T@B 320 Max S
Yes, there is no fix I'm aware of. I recently purchased two new windows with the new metal hinge design, which I will have installed this Saturday. It's only a matter of time before the window I currently have fail again.2021 T@B Boondock 400. 2021 Toyota SR5 V60
Has anyone replaced the front window of a 400 themselves? I ordered a new window assembly (about $600) and I am looking for installation advice or video.John & Michelle & JD (Just Dog) 2019 T@B 400 Boondock LTE towed by a 2017 Toyota Highlander v6, (flat land only) or a 2017 Tundra v8 (when going west)0
@Hops, I am not aware of any specific replacement for the hinge, but maybe (if you have not already seen it) this fairly recent discussion (by @Maxcamp) regarding replacing the front window of a 2021 T@B 320 S will be helpful to you:
https://tab-rv.vanillacommunity.com/discussion/19631/replacing-2021-320-front-window-with-new-version#latest
Also, this company has been mentioned previously as a possible source for parts, so you might consider contacting them for suggestions:
https://transatlanticprod.com/products/2019 T@B 320 S Boondock Lite ~ 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)0
