Just here in Montana, stove works getting gas failure and below it fan failure when I try to run the
Alde heat on propane. No electric for now. Lithium power says good.
2022 T@B 320 S Boondock  "UGA", Jeep Gladiator Overland
North Georgia
  • Grumpy_G
    Grumpy_G Member Posts: 784
    The manual says to disconnect power to the boiler for 5 minutes. Probably easiest to turn off the battery for 5 minutes (assuming no shore power). AFAIK this is a fan that helps moving hot exhaust gas to the outside. More info here: https://tab-rv.vanillacommunity.com/discussion/5023/alde-fault-message-fan-failure
  • Binghi
    Binghi Member Posts: 416
    Agree with @Grumpy_G. Same thing happened to me. Finally figured out to turn off the battery disconnect switch, then turn it back on.The Alde started working again.
  • ybakos
    ybakos Member Posts: 60
    edited October 2024
    I did the same thing but mine still fails. :angry:
    This Alde has been nothing but annoying disappointment. It has only been used 20 times, so it is not like it is under stress from overuse.
    2022 Tab 320 CS-S Boondock
