UV Water Sanitizer
I started looking at RV UV water sanitizers.  Has anyone installed one of these?  Is it possible to add a UV light in the water tank for sterilization?
I've always used the bleach process and would probably still do it after storing the trailer for a while, but thought this might be a good addition.  We usually use bottled water for drinking and the tank/camp water for washing dishes, showers, etc.  Might just add one on the kitchen sink faucet.
2022 T@B 320S Boondock
  • Mickerly
    Mickerly Member Posts: 518
    You don't wash your face in the bathroom? If you are going to install a UV filter, you may as well install it at the front of the system and clear all water in the trailer.
    You will have an annual bulb replacement or you can turn it on and off.
    2018 320CS-S
    "Just Enough"
