T@B 400 Front Storage Box Noise
We recently took our 2023 400 on its maiden voyage, which towed behind an AWD Honda Pilot just fine... except for one annoyance. There is a frequent metal clanging noise coming from the camper once we get up to speeds above 35 mph, and very frequent at highway speeds. It appears to be coming from the metal storage box, but I have yet to successfully even diagnose it yet, much less pursue a solution. Among the things I tried:
  • Took everything out of the box, in case something is jumping around in it
  • Damped the interface between the hinged lid and the box with towels
  • Damped the tiny gap between the top of the propane cylinder and lid, again with towels
  • Removed the propane cylinder entirely
  • Drove with the lid open rather than closed
Same noise, every time, which may indicate that its coming from the bottom of the storage box, or even elsewhere. Has anyone else had this problem, and if so, how did you address it?
Thanks in advance. Apologies if this has come up before, but I couldn't find it in a search.
Tom
  • CatDaddy
    CatDaddy Member Posts: 135
    Are you sure that the noise isn't from the drawbar rattling in the hitch receiver? I just took my 2022 320S Boondock on it's maiden voyage. The hitch receiver popped and rattled at low speeds. It was quiet at high speeds.
    Maybe the mount for the spare wheel is loose?
    2022 NuCamp T@B 320S Boondock
    2014 Volkswagen Touareg TDI AWD
  • WayneW
    WayneW Member Posts: 263
    Yes, I agree with @CatDaddy. I put an anti-rattle hitch stabilizer on and it eliminated the rattle. Give one a try.
    2021 320S BD
    2017 F-150
    Coeur d'Alene, Idaho
  • TomPolakis
    TomPolakis Member Posts: 6
    Thanks. Sounds like an inexpensive thing to try. I'll give it a shot.
  • SLJ
    SLJ Member Posts: 669
    Is the spare tire tight? Could be the cable holding it up is loose.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • CatDaddy
    That's a good thought! I was thinking his spare was mounted on the tongue, but if it's underneath, it could be rattling.
