T@B 400 Front Storage Box Noise
TomPolakis
Member Posts: 6
We recently took our 2023 400 on its maiden voyage, which towed behind an AWD Honda Pilot just fine... except for one annoyance. There is a frequent metal clanging noise coming from the camper once we get up to speeds above 35 mph, and very frequent at highway speeds. It appears to be coming from the metal storage box, but I have yet to successfully even diagnose it yet, much less pursue a solution. Among the things I tried:
Same noise, every time, which may indicate that its coming from the bottom of the storage box, or even elsewhere. Has anyone else had this problem, and if so, how did you address it?
Thanks in advance. Apologies if this has come up before, but I couldn't find it in a search.
Tom
- Took everything out of the box, in case something is jumping around in it
- Damped the interface between the hinged lid and the box with towels
- Damped the tiny gap between the top of the propane cylinder and lid, again with towels
- Removed the propane cylinder entirely
- Drove with the lid open rather than closed
Tom
Are you sure that the noise isn't from the drawbar rattling in the hitch receiver? I just took my 2022 320S Boondock on it's maiden voyage. The hitch receiver popped and rattled at low speeds. It was quiet at high speeds.Maybe the mount for the spare wheel is loose?Adventure Cats living in the Pacific NW USA
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD1 -
Thanks. Sounds like an inexpensive thing to try. I'll give it a shot.0
Is the spare tire tight? Could be the cable holding it up is loose.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
That's a good thought! I was thinking his spare was mounted on the tongue, but if it's underneath, it could be rattling.SLJ said:Is the spare tire tight? Could be the cable holding it up is loose.
2023 Volkswagen ID.4 Pro S Plus AWD0
- 920 Introductions
- 75 Teardrop Groups & Links
- 917 Tips & Tricks
