Added a disconnect switch for the radio T@b 360
There was some recent discussion about tracking down "phantom" power draws, including the radio unit which uses power in standby mode. Personally I just wanted to be able to turn it off entirely as we rarely use it, and I don't like the light from the clock at night (plus the clock is never the correct time anyway). Pulling the fuse triggers another LED on the converter, plus we do want the sound system to be able to work occasionally.  I previously pulled the TV out completely, so this is just for the radio.  It is not difficult. In case you have little or no knowledge of this type of thing, here are some step by step instructions.
1. Turn Battery Disconnect to OFF with red knob
2. Gently pop off the bezel around the radio. Pry with something thin and plastic.
3. Remove the 4 square head screws and carefully pull out the radio and wiring.
4. You will need to find the wago connector with the red wire that is labeled "+12V DC Switched"
5. Lift the tab and remove the red wire.  You will need to go from that wire to a switch, then back from the switch into the same location in the connector. I.e., the switch will be able to interrupt the 12v power to that connector.
I used a switch I had on hand, and decided to put it in the storage box behind the radio. Any light duty switch should work fine you can find something at the hardware store or Amazon, or harvest from some old electronic device. I drilled through from the storage box into the radio cavity -make sure the wiring is out of the way. Depending on your switch you will have to decide how it mounts. Mine had a threaded retainer, and I filled in around it all with hot glue.
6. Attach 6" of flexible wire to the switch. Use a wire gauge similar to what you see feeding the radio. 16 AWG if you are going to buy some.
7. Mount the switch
8. Connect one of the switch wires back into the wago 12v supply connector. Connect the other switch wire to the red wire you removed from that connector, the one with the +12v sticker.  Its best to solder the wires and use heat shrink tubing, or use a crimp connector, or you could use a small wire nut and wrap a bit of electrical tape around it.
9. At this point I would turn on the power and test, then turn off the battery power and put everything back together.
  • Mcbret
    Mcbret Member Posts: 20
    Wow...simple solution. Thanks. My radio works fine and I am not so worried about a "phantom current draw" but, the stupid thing comes on by itself...usually in the dead of the night!!!! Now, a simple fix to keep it off until desired. Thanks!!!!
    Karen, Bret & Banana Widdifield
    2021 T@B 320s Boondock "Pull-T@B"
    2024 Nissan frontier Pro-4X
    South-Central Indiana
  • SLJ
    SLJ Member Posts: 666
    Typically if it comes on by itself the timer is set.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • NMSunshine
    NMSunshine Member Posts: 29
    Nice rundown, I have a 320s but similar setup, nice to see they are using Wagos and some labels on the 360, I haven't seen any of those so far in the 320.
    2021 T@B 320ss Boondock - added Victron Smartshunt, 400w Renogy and 200w BougeRV folding solar suitcases, additional Victron 100/30 MPPT controller and eco worthy 300ah smart lifepo4 battery.
    2011 Tacoma TRD Off Road (V6, Auto), Dobinsons MRR adjustable suspension, 3in lift
    Albuquerque, New Mexico
  • MarkAl
    MarkAl Member Posts: 510
    I will occasionally find the radio cannot be turned ON (but the time is displayed). I believe my system sometimes gets a glitch either in sw or hw that requires power recycling so I've been pulling the radio fuse to reset it. I've avoided the switch but it would be a lot easier.  This has happened only about once a year so it's only been mildly annoying.
    managed by VE Smart Network
