Tab 320S: Wet spots inside of the Tab.
When I was recently working on wiring on my Tab, I noticed wet spots inside of the Tab. It's located around the Nautilus, on the driver's side. I'm suspecting that there might be something wrong with how the Nautilus is installed. Does anyone have the same issue?
Tab 320s Boondock 2022 | Jeep JKU 2017
  • rfuss928rfuss928 Member Posts: 1,015
    In my UT the Nautilus hose port is right behind the left tire and allows wet weather tire spray to enter the box which is not sealed from the trailer interior.  A foam plug placed in the hose port below the snap cover solved a similar issue in my case.  Additional sealant between the Nautilus box and trailer outside wall is an additional preventative measure.
  • Basil48192Basil48192 Member Posts: 339
    I have a 2021 320S and noticed, right after I bought it, that water was accumulating inside the camper in that same area.  I determined that it was coming in from the Nautilus compartment after connecting and disconnecting the hose.
    It was leaking in from the openings for the low point drains (circled in the photo below).  I squeezed some clear, silicon caulk into the corners and around each pipe.  You can't really get to the bottom of the pipes, so I forced it into the area with my finger to the extent possible.  It's not very pretty, but it worked really well.
    I am also very careful when I use the compartment, making sure to wipe up any overflow and keep the area as dry as possible.
    Hope this helps!
  • californicationcalifornication Member Posts: 29
    Thanks.
    I'll take a close look for possible leak spots.
  • BillJ70BillJ70 Member Posts: 2
    edited November 5
    Also, mine was leaking from the corners closest to you in that compartment.  There was no caulk in those area and it was letting water through.  I had to use my cellphone and point it backwards to see it. This is facing the outside of the camper (in the Nautilus box).  It was like this on both sides-- water was coming into the camper and out from some seams underneath.  I saw another post yesterday (different subject) where someone described this same issue.
