Specifications for the Sun Flare PV panel
Does anyone have detailed information regarding the Sun Flare solar panels used on the Boondock versions of the Tab series? I specifically interested in the panel used on the 2022 320S Boondock. I can’t even find the power or open-circuit voltage ratings for it.
I’m asking because the previous owner of my 2022 320S just wired a Harbor Freight mono-crystalline panel in parallel with the Sun Flare panel. I’m surprised that it seems to work, after a fashion. I highly doubt it’s optimal.
2022 NuCamp T@B 320S Boondock
2014 Volkswagen Touareg TDI AWD
  • skibug
    skibug Member Posts: 12
    I know you asked for 320 S but this is the spec sheet for what we have on our 2023 320 CSS.
  • CatDaddy
    CatDaddy Member Posts: 135
    Well, that's interesting! Now I'm wondering if the panel on my 2022 320S BD is Sun Flare or Xantrex!
  • rfuss928
    rfuss928 Member Posts: 1,197
    This is the spec sheet for the Sunflare 162 watt solar panel added to our UT by NuCamp Service Center in Aug 23
  • CatDaddy
    Thanks! That's very helpful! I will attempt to see if the dimensions shown match my panel.
    The question about Xantrex panels came up a couple of years ago.  It may have been a very short term solution.
  • CatDaddy
    That's helpful as well.  My panel does not have grommets so it's probably a Sunflare panel.
  • CatDaddy
    In any case, putting either panel in parallel with the Harbor Freight 100W Thunderbolt panel seems like a poor idea. Harbor Freight says the voltage is 18V.  Don't know if that's the open-circuit voltage or the maximum power voltage, but either way, it's not 25-32V of the Sunflare panel.  I'm really surprised that adding the HF panel helped at all.
  • ckjs
    ckjs Member Posts: 144
    If the low voltage panel is in the sun (e.g., as with the Harbor Freight one in a portable frame) while the Sunflare is shaded on the roof, the HF panel could help some. If both are in equivalent sun then the lower voltage panel probably doesn’t help at all.
  • Horigan
    Horigan Member Posts: 928
    You may want to consider putting the panels in series, assuming your controller can handle the voltage.
    Rich
    2019 T@b 400
    Bellingham WA
  • CatDaddy
    Putting panels in series without their own MPPT hardware results in the string current being the same for both modules, which is almost never optimal. It does solve the problem of two chargers fighting each other over what state the battery is in and therefore what state the charging should be in.
  • Horigan
    I was thinking both in series through a single controller, assuming that's possible with the HF panel.  However, that wouldn't be practical with the HF panel being portable.
    Rich
    2019 T@b 400
    Bellingham WA
  • ckjs
    Two MPPT chargers in parallel don’t “fight each other”; it’s more like they cooperate as best they can. If they have different charging schemes, then one is likely to read the voltage provided by the other as a sign to stop charging, and subsequently it will go idle.
    It would “waste” some solar energy, but that isn’t going to be a big deal.
    Mixing different PWM chargers, or an MPPT and a PWM, would probably also be “wasteful”.
  • CatDaddy
    Actually, they do fight each other. I'm an electrical engineer that designed charging systems. For that reason, Victron has a feature that uses the VE Direct wireless Modbus interface to allow Victron devices to synchronize themselves to cooperate instead of fight.
  • ckjs
    CatDaddy said:
    Actually, they [chargers] do fight each other…
    Ooh, thanks for the correction. Could you point me to a description of the interaction? I did some EE when I worked, and still am curious about just about anything.
  • CatDaddy
    I will look for something better but here’s some information: Victron VE.Direct synchronization allows multiple solar charge controllers to communicate and coordinate their charging stages, ensuring they share the load effectively. This setup helps prevent weaker chargers from dropping to float mode too early, optimizing the overall charging process.
    https://duckduckgo.com/?q=victron+VE+direct+synchronization&t=iphone&ia=web&assist=true
  • CatDaddy
    Here's a slightly better description of why synchronization is needed. I'm not even convinced that the WFCO and the factory Victron 75/10 MPPT Controller get along well together, but I suppose that when one is using the solar array, the WFCO isn't typically connected to shore power at the same time:
