Ack! Maiden Voyage tomorrow!!!
ELK
Member Posts: 213
Yes..I'm a little nervous! Any tips for driving or hooking up? Also! I turned the fridge on AC power and also flipped the switch all the way on the right (2015 Max S) so the green light came on. I assume that is necessary?
2015 T@B Max S. TV: 2015.5 Volvo XC70.
The green light on the fridge should only come non if you are on propane mode.
What Jenn said - and that's the only green light I can think of.
But it's a switch you turn on and off....sounds like a fan. The manual does not address it at all. It has a green light on it that comes on when you turn it on. I should take a photo.
2015 T@B Max S. TV: 2015.5 Volvo XC70. -
Ok, it's probably the new exhaust fan for the fridge - exhausts out the side vent. I don't have mine yet. Knew about the switch but didn't know about it having a light. Or a light coming on. Could post a pic so we can see for sure.
We had the new frig mod completed and the switch does have a green light. I don't plan to use it in the cooler weather, the frig is like a heater.Judy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
Once I get mine installed, I'm with you judymac, on during warm months, off during cool.
Hey Elk - I think PXL is right. It's your fridge vent fan -- the fan on our 2015 was installed by our dealer after we had the trailer but the tech said he put it where the factory was putting them in the new rig. It is a rocker switch and has a green light, and runs a fan that exhausts warm air from around the fridge. We used it in the hot AZ summer but like PXL, I think we won't when it is cooler. If I can get the picture to load, here is where it is:
2015 T@b S Max | 2015 Jeep Wrangler Unlimited | was PHX East Valley, now Dallas! -
Yes...that's it! SO I don;t have to turn it on unless it's really hot....Thanks !
You can turn it on whenever you want but the reason it exists is that the fridge generates quite a bit of heat you may want to exhaust when it's hot out and/or when you have the air conditioner running. If it's chilly out, you may want to leave it off and let that heat help warm up the T@B
- 917 Introductions
- 73 Teardrop Groups & Links
