Electric Brake Connection
elbolillo
Member Posts: 575
This is just an example of the need for regular inspections. As you can see from the attached photo, one of the electrical connections to the brake came undone—a fairly easy fix. However, how they ran the cable leaves a lot to be desired. It is not secured in any fashion, and there is a lot of play in the cable from where it enters the undercarriage. We have just had a blast of arctic air hit us, so once I can get the 400 inside, I will need to tidy this up.
