attaching light strings
Cut pieces of 5/8ths round foam weatherstripping for the Kidder Rails:
Use micro plastic wire clips for under the Kidder Rail on passenger side.  They come in white, so I painted mine to match the trim:
Micro hairclips for attaching string to XL visor.  You'll need 18:
A 30 foot string fits perfectly on the side of a 320.  The visor only needs 20 feet, so you can simply cut off the excess lights:
They are battery operated.  3 "AA" cells for each string. They have 8 different modes.  The cafe lights are dimmable in the "solid" mode.
2016 Outback 320
  • SLJ
    SLJ Member Posts: 666
    edited January 2025
    I like the foam idea. Mine are small LEDs that fit inside the Keder rail channel but the foam plugs would help. My strings are USB powered so I added a weatherproof USB port to power them (and a 12 volt port) next to the outside AC outlet. I use medium binder clips to attach them to the edge of my awning. Also good for the shades.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Cherokee
    Cherokee Member Posts: 346
    Clever !
    California, USA
  • ColleenD2
    ColleenD2 Member Posts: 583
    I like Klippy Klips. I bought mine at Camping World.
