The tape is at 9" (the case is 3") = 12 " clear at the rear axle with the T@B setting level. The prospective in the photo eludes to lower clearance beyond, but at the rear axle is the lowest point. My metal bottom looks a little different, but it fastens to the bottom of the cold rolled frame like the stock plastic cardboard. I have 235/75/r15 tires with a stock "pitched" axle. My step measures 14-1/4" from the bottom of the frame to the ground.- I have no idea what the dimension on that link was measuring. My waste pipes have more then 12" below them. I believe the 2021's are the same - hope this helps
