Simple Amber Coating for Bright LED Porch Light
Tabaz
Member Posts: 2,420
I never use my outside porch light because it is way too bright and draws bugs.
Found this film on Amazon for $7.55:
https://www.amazon.com/dp/B0B5WYXRWV?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
The film is fairly transparent, so you may want to use two or three pieces on top of each other (I used three). Be aware that there is a clear film on top of the colored film as well as a backing on the other glued side. You will need to remove both. A fresh X-Acto knife is a must. Cut a piece of light cardboard to 7/8" x 5 7/8." Use the cardboard as a template to cut a piece to fit - however, leave an extra inch on one of the long sides because it is almost impossible to use the knife to separate the clear film on top or backing on the bottom. Simply "rough up" the end with the extra inch to separate the clear and backing films with the knife. Once both films are removed, start at the "good" end and place over the stock lens. Once on, cut the "bad end" off with the knife. Repeat the process for how many layers you wish.
After almost ten years of use, my "T@B" emblem under the porch light was really faded. It is easily removed with a plastic putty knife. Clean the remaining adhesive with Goof-Off and sand off the old silver paint. Use a very thin double-sided tape (3M 300LSE). Cut the tape into several small pieces and place on the back of the emblem so as not to show once installed.
https://www.amazon.com/dp/B07LFXHBKV?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
2016 Outback 320
YES, I know why you changed it. - NuCamp got the message and put and yellow/orange porch light on my 2019 320. It's easy to see an night
TV:2019 Nissan Frontier PRO-4X With an Old Man Emu liftTrailer: 2019 T@B 320 Boondock with a Lock&Roll Coupler & Jack-e-upCustom fabricated metal bottom claddingCalifornia, USA0 -
Turn signal repair tape does the same thing. It may be found at your local auto parts store.2018 320CS-S
"Just Enough"1 -
I use yellow electrical tape, but all the above are improvements over what NuCamp had installed on our (2019 - 2018 Mfg'd) Tab.2019 Tab 320 CSS, 2019 Ranger TV, OH0
I wish I would have known about the turn signal repair tape. Putting on three layers of this stuff was a little too labor-intensive.2016 Outback 320
I covered the lens on mine with two layers of red gel paper. No bugs and works in dark sky parks.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York0
