320S Water Pump Access Panel Latch
Explorers2
Member Posts: 41
Hello! I need to replace the latch that holds the small access panel door shut that is located behind the toilet in my 2019 320S. The latch came apart and parts fell down into the belly of the camper, not to be retrieved, and now the door will not stay shut. I've asked my local dealer for a replacement but they say NuCamp operates by email and they want a picture. My camper is at my lake house in MN, and I am in Colorado till summer.
So...does anyone have a picture of this latch, or know where there might be one archived? Or know of an Amazon level replacement that would work?
Thanks!
John
Thanks!
John
Hi @Explorers2, it took me a little searching to find these for you, but they are of the access panel and latch in my 2019 320 S, so they should be what you need. Your dealer may actually have the same/similar latch in stock if they sell parts. Otherwise, an RV supply store (or Amazon) probably also carries them. My trailer is in storage, so I can't get you a quick closeup of the latch itself.
You can also do an online search for "RV compartment door thumb latch" or "RV compartment door twist latch" or similar terms.
If you find a matching latch, you may have to separately purchsase the "finger pull" that works with the latch, such as this one from Amazon:
https://www.amazon.com/RV-Designer-L539-Finger-Pull-Compartment/dp/B0020YP00O/ref=asc_df_B0020YP00O?mcid=0e34c0511a3b38dba0dcd26e6755d5db&hvocijid=10412718452061822724-B0020YP00O-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=721245378154&hvpos=&hvnetw=g&hvrand=10412718452061822724&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9220048&hvtargid=pla-2281435177658&psc=1
Good luck!
Thanks very much Bayliss! If the dealer has this, great. Otherwise I think I can get one on Amazon as you suggest. However I'll have to wait till I'm up with my camper as I don't know what diameter this latch is. Some are 7/8, some 1", etc...0
