Loose Thetford Toilet valve spring - need photo
Maxcamp
Member Posts: 352
Thetford cassette toilet model C403L on 2021 boondock TAB.
While cleaning the TAB compartment holding the cassette, dislodged the valve actuator spring.
Can someone tell me where and how the spring attaches to the lever? Is there a clip missing? No detent on the metal rod end, spring slips off.
The apparent slot is not where it goes.
A picture would be great- can someone remove their cassette and snap a clear photo looking up at this assembly?
No takers. For posterity here's the fix.
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck1 -
Thanks for sharing Maxcamp!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
the spring attached to an piece of plastic with a hole in it that is missing from your photo. it has been broken off. Happened to me and I just ordered a replacement part0
@Tabnero, can you post the part number? Maybe a pic when you get it in as well. Thanks.
My fix works well, but the spring is stretched and I wonder if it will twang off or break while in use at some later date.
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck0 -
pages 34 and then 44 through 48 or so. not sure if part numbers are here put you can get them from the website0
