Gooey "disk" from grey tank drain
Gkopan
Member Posts: 47
During de-winterizing, after flushing the system with fresh water, this crud came out when draining the grey tank. About the diameter of the drain pipe.
Was my winterization process deficient? Thanks!
2021 T@B 400 Boondock; TV: 2019 F150 3.5 EB
Did you winterize by adding antifreeze throughout the plumbing system? That almost looks like something dried up in your tank. Was your gray tank clean before you winterized?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
