Magic Smoke from 2018 400 converter cable.
pthomas745
Administrator, Moderator Posts: 4,705
Someone knows this, but I can't find any info. This photo showed up on one of the FB groups this afternoon.
What is the white wire and where does it come from?
And, the fuses seem a bit off, especially the 7.5 amp ratings...this is from a 2018, so maybe the fuse setups I see in the "Tab 400" guide that is in the files from a couple of years ago are very different.
Is the cable here the 12V wire to the bus bar behind the converter? Guessing from this thread below, simply based on the wire gauge.
I'd think so as well, in any case the other wire in that double terminal block looks pretty smoked as well. The block connects the converter to the rest of the trailer including the battery. Did the FB post state if that happened while plugged into shore power ?0
Hi,
If you watch this video, it comes from the DC side of the converter. About 13:50 point of the video.
WFCO Power Source Training2025 360 CS
Southern Maryland0 -
Did this involve a lithium battery?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
If one ZOOMs the above picture, the burnt White Wire is connected to a PCB Terminal Labelled NEG-. It is the Power Center DC Voltage Ground and does connect to the trailer Ground Wires Bus.
The thread in the link has pictures of 320S ground bus.
And while we have limited 400 wiring reference material, several early year builds had the 400 Ground Bus on a wall panel behind the Power Center.
I once Burned Out the white Battery to Ground Bus Wire on my 320S when I shorted the Battery Positive to chassis ground (with a wrench that slipped out of my hand).
There has had to be some type of very high current short to cause the damage shown in the picture.
Reference Picture:
Hi,
If you look closely, is there a missing wire on the left of the two position lug bar? Does one wire come from DC side of the converter (white wire on right) and the other connect to the 12V ground bus (left position)?
2025 360 CS
Southern Maryland1 -
Thank you everyone, still waiting for answers to your questions from the owner.
@Yoshi_TAB the wire on the left is fried, too.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
