entry step upgrade
Hello, I own a 2009 T@B & would like to add an 'attached' fold away entry step instead of using a portable one. Wondering if it's possible & would love to hear from anyone who has done this. Thanks,  Jane
  • rfuss928
    rfuss928 Member Posts: 1,197
    There is no structure in the floor or a frame able to support the loads of an attached step.  I've never seen it done.
  • SLJ
    SLJ Member Posts: 669
    You might be able to attach a "Fold UP" step as they attach to the floor and door sill, not underneath on the frame. I don't like them though as the step has to be down to enter or exit. Lippert and MORride both make them in different heights. A T@B door is pretty narrow though.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • EasternJL
    EasternJL Member Posts: 108
    I know you are looking for something attached, but we never had luck with that.  But we did find something better than most of the portable ones.  We used this step ladder with our 320 and it worked perfectly-- giving you two steps instead of one. And because back support folds down, it tucks right up to the door.  And it also helped for putting on cover, awning and stepping into truck bed.
  • EasternJL
    And by the way-- since our 320 was a Boondock-- your step heights relative to the height of your trailer might not work the way it did for us (and this particular step ladder).
  • Tabaz
    Tabaz Member Posts: 2,420
    I attempted to remove a friend's factory step for a repair on an older 320.  Could not get the nuts off the bolts.  The bolts simply kept turning in place.  This lead me to believe the bolts are not attached to a metal frame.  We had to leave the factory step in place.  She purchased a small step stool that works fine.  I never use my factory step. I bought an aluminum folding step from Harbor Freight years ago.  It is the perfect height for my 320 Outback.  Less than $30.
    2016 Outback 320
