Summerizing
Explorers2
Member Posts: 41
Ok I’m “summerizing” my 2018 320. I’ve loaded a full tank of fresh water and am running that through all the systems, including the alde water heater. There seems to be a lot of air in the system to purge, especially on the hot water side. The connections to the pump are tight and not leaking and no leaks from anywhere under the camper (which I assume I would see if there was a broken pipe). I’ve run about 75% of the tank through, according to the led panel. Is this typical?
Not sure what you are trying to do. To purge a large amount of air from the plumbing system. it is better to hook up to city water and open your cold taps then open your hot taps and let the Alde tank fill. The LED tank indicator usually over estimates the tank volume.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Thanks Sharon! Ran out the air w city water now everything works great!2
