Alde leak under the shower pan.
3sport73
Member Posts: 4
I Have a 2020 Tab 400. I discovered Alde fluid under the dinette table. It came from the front left side under seat storage area. Tracing back further, the source is from a loose convector connection under the shower pan. It can been seen by removing the wood access panel under the door. There is no way to get to it from this spot as the shower drain p trap is in the way. Anyone have experience in taking up the shower pan and its plywood support subfloor? It appears to me to be the only way to get a clamp tool on the end of that Alde hose. Thanks in advance.
2020 Tab 400 Boondock--2006 Lexus GX470.
Ouch. Can you get us some photos? Can you tell if the loose hose clamp is due to any "swelling" under or around the clamp, with possible damage to the aluminum convector below it.There are some threads about repairing a "squeaking" shower floor that might help show you what is under the "pan" part of the shower floor. So, a picture might help.This thread has more detail, with an owner who changed the p-trap to a Hepvo. And, there is a picture that shows the convector you mention.
Unfortunately my older iPhone camera lost its ability to focus on any near field object. I'll try to get another device to get a photo of it. Thanks for responding. I'll check the links you provided.2020 Tab 400 Boondock--2006 Lexus GX470.1
