2015 T@B Max-S, Four season camping, Alde radiant heat extended under floor, Hansville, WA $17,500
dougsterdougster Member Posts: 1
2015 T@B Max-S, white with orange trim aka Dreamsicle, in excellent shape and well maintained by current owner since 2016. Stored indoors most of it's life, fits in an eight foot tall garage door.
Features:
Alde radiant heat system, wall mounted AC, alloy wheels, 3 way refrigerator (with added cooling fans), 19" entertainment center, sliding screen door, 3 speed Fantastic fan, PahaQue visor awning with new heavier duty fiberglass poles, dual pane acrylic windows with accordion blinds and screens
Custom mods:
Alde radiant heat system extended under floor and attached with aluminum plates to fresh and grey water tanks. Insulation added under floor space and corrugated plastic belly board with 1/2" foil faced foam insulation installed. - Jan 2019. Lots of photos available. All Alde fittings, clamps and tubing purchased from Nucamp.
Flow through radiant heat vents installed under seating. Rear shelf modified to allow more heat to flow through
Renogy 100w solar panel mounted on a satellite dish variable angle mount with solar controller and battery meters
SeeLevel II 709 tank monitor system.
Table mounted to wall under window and TV. Original table stand included. 110v wall outlet added under TV
Multiple bed setups possible - Bench seat extension to allow two "twin" beds or single bed with bench seat or original 6'x6' king size bed.
Factory seat foam cushions replaced with a little stiffer foam - Nov 2017
Storage for dump hose under front box
Refrigerator thermostat controlled cooling fans added for hot weather June 2024
Maintenance:
New tires May 2025
Wheel bearings cleaned and repacked with new seals, brake inspection May 2025
Alde heat transfer fluid flushed and filled with 5 year fluid Nov 2023
Replaced original manually adjusted brakes with new auto adjusting electric brake assemblies and hub assemblies March 2022
We are selling because as we grow older, the Dreamsicle has seemed to have gotten smaller.  We have decided to upsize a little to a 17' Jayco.
Please call Doug 360-860-1746 or email dougstered@gmail.com for more info. Please no texts for info.
Asking $17,500
