Tab 360 Faucet Fail
My journey to bring my new 360 up to snuff continues and this month I am concerned with the bathroom faucet. It is a combined shower head and faucet that has a switch in the handle to switch from shower stream to faucet stream.
It works poorly:
* It has a high flow and uses far more water than my Tab 320 shower head
* There isn’t an off button on the shower handset.
* The buttons on the handle beneath the rubber are clicky and smudgy and cranky (hard to describe). Difficult to reliably click.
I am trying to get it corrected under warranty, but the dealer is saying that it operates as designed. Is that possible? Does anyone else have one that works similarly badly? Do I have upgrade options?
(previous 2018 T@B 320 Outback, 2021 Jeep Grand Cherokee V6)
Maryland
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    edited October 2025
    Hi,
    We have a 360CS and like the option of the faucet to change from spray (shower)  to stream (to wash our hands and brush teeth).  We have an inline small ball valve to turn ON/OFF.  It still hangs fine for a shower.
    Agree the stream uses more than a shower head and the button isn't smooth.  I've looked around for another choice with stream/shower combo.  Found a few in the boating world...but they were very expensive ($50-$70) and did not look like they would hang well in the OEM bracket.
    2025 360 CS
    Southern Maryland
  • SLJ
    SLJ Member Posts: 666
    Most shower heads with a switch don't shut compleately off so pressure doesn't build up in the hose. It most likely works as designed. You will have to add an on/off switch below the head but then make sure the facuit is off and the head switch is open when not in use so the hose doesn't build up pressure and burst in the heat.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Gomers2
    Gomers2 Member Posts: 171
    @Yoshi_TAB, I find it very amusing that you have the H on there with sharpie. I cannot, for the life of me, remember which way to turn that thing 😂
  • Trailpixie
    Trailpixie Member Posts: 205
    @Yoshi_TAB what did you find in the boating world? Do you have any links?
    Maryland
  • Yoshi_TAB
    Hi @Trailpixie,
    Here is one example Scandvik Combination Faucet/Shower with Adjustable Aerator | Defender Marine
    Do a search for Boat  head shower sink faucet only and a bunch show up.  You can find just the faucet part w/o the sink ON/OFF
    2025 360 CS
    Southern Maryland
  • Trailpixie
    That IS pricey.
    Maryland
  • Horigan
    Horigan Member Posts: 920
    Also search marine faucet.
    Rich
    2019 T@b 400
    Bellingham WA
  • ckjs
    ckjs Member Posts: 143
    One thing to consider is that you don’t get the full (e.g., 3’) amount of pull-out extension unless your counter has 3’ of clear vertical space underneath it. The hose is pulled back into the faucet by a weight that’s attached to the approximate middle of it.  You could position the weight to allow it to pull out further, but then you’d have to push the hose back in 😕.
    I replaced the kitchen faucet in our CSS with a typical home pullout; it has only 16” or so of extension.
    I’m still looking to buy or build a spring-loaded take-up reel for the hose, so that we could use its full length.
