Tab 360 Faucet Fail
Trailpixie
Member Posts: 194
My journey to bring my new 360 up to snuff continues and this month I am concerned with the bathroom faucet. It is a combined shower head and faucet that has a switch in the handle to switch from shower stream to faucet stream.
It works poorly:
* It has a high flow and uses far more water than my Tab 320 shower head
* There isn’t an off button on the shower handset.
* The buttons on the handle beneath the rubber are clicky and smudgy and cranky (hard to describe). Difficult to reliably click.
I am trying to get it corrected under warranty, but the dealer is saying that it operates as designed. Is that possible? Does anyone else have one that works similarly badly? Do I have upgrade options?
T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
Hi,
We have a 360CS and like the option of the faucet to change from spray (shower) to stream (to wash our hands and brush teeth). We have an inline small ball valve to turn ON/OFF. It still hangs fine for a shower.
Agree the stream uses more than a shower head and the button isn't smooth. I've looked around for another choice with stream/shower combo. Found a few in the boating world...but they were very expensive ($50-$70) and did not look like they would hang well in the OEM bracket.
2025 360 CS
Southern Maryland0 -
Most shower heads with a switch don't shut compleately off so pressure doesn't build up in the hose. It most likely works as designed. You will have to add an on/off switch below the head but then make sure the facuit is off and the head switch is open when not in use so the hose doesn't build up pressure and burst in the heat.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
@Yoshi_TAB, I find it very amusing that you have the H on there with sharpie. I cannot, for the life of me, remember which way to turn that thing 😂1
@Yoshi_TAB what did you find in the boating world? Do you have any links?T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)0 -
Hi @Trailpixie,
Here is one example Scandvik Combination Faucet/Shower with Adjustable Aerator | Defender Marine
Do a search for Boat head shower sink faucet only and a bunch show up. You can find just the faucet part w/o the sink ON/OFF2025 360 CS
That IS pricey.T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
Also search marine faucet.
Rich2019 T@b 400
One thing to consider is that you don’t get the full (e.g., 3’) amount of pull-out extension unless your counter has 3’ of clear vertical space underneath it. The hose is pulled back into the faucet by a weight that’s attached to the approximate middle of it. You could position the weight to allow it to pull out further, but then you’d have to push the hose back in 😕.
I replaced the kitchen faucet in our CSS with a typical home pullout; it has only 16” or so of extension.
I’m still looking to buy or build a spring-loaded take-up reel for the hose, so that we could use its full length.Charles & Judy, Santa Cruz, CA
2018 T@B 320 CS-S; Alde 3020; 4 cyl 2020 Subaru Outback Onyx XT0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
