Got out to the camper to winterize it, we were running the pump off the batteries. Set the Nautilus handles to the "winterize" position, put our gallon of RV antifreeze on the ground with our suction hose in it (piece of solid garden hose, so it won't "collapse" from the suction.) Once the suction started, turned on the outside faucet until it flowed pink, did the kitchen sink, did the toilet, did the bathroom sink.
The shower wand, however, was difficult. Despite turning on the water and leaving it for a minute, NOTHING came out of the wand. Some water did come out when I put the wand on the shower floor, presumably it was "gravity fed" from the hose, but that was it and no indications anything was going to be coming through.
Now, we did not use the shower at all this season, so my question is, should I play it safe, go back to the camper, put the remainder of the antifreeze back under the hook up and run that shower until it flows pink? Or should we be OK?
I did, a few weeks ago, open the yellow drains under the bed (both of them) until the water stopped flowing, as well as the side drain behind the wheel, so I'm fairly confident the lines are as dry as they're going to get.
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
0 ·
2019 T@B400 Boondock Lite "Todd"
Jay and Kat
@Jay_and_Kat just for clarity I needed to mention the Alde hot water tank. I do not have the Nautilus in my 2019 so there are two more yellow drains for that in my Alde compartment to drain that tank. Wondering if your winterize setting takes care of that? That is not one that would be recommended for antifreeze from what I recall.
So I'm also certain there's no antifreeze in the hot tank, but thank you for thinking of it! I'd rather be reminded and not have to do anything, than not be reminded but I forgot to do something and have problems later!
Jay and Kat
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
2020 Tacoma TRD Off-Road
@tabiphile what I noticed today when trying again is, with the pump on and the shower turned on for full cold (or hot,) the level of antifreeze in the jug doesn't go down, or if it is, it's so little as to be imperceptible. I did check that the pump should've been working by re-opening the sink faucet and I did get antifreeze out. I did lift the bed over the Nautilus compartment to verify, and the pump was running (I could feel it when I put my hand on it,) but I couldn't see any indication of fluid going through nor was there any sign of a leak back there.
What I'm thinking now maybe, is that the section of water hose I use to put in the antifreeze jug is that is might have a permanent "partial crimp" in it, so I bought a new length of hose to cut down to use and I'll be going back out AGAIN (LoL) to try to get the shower flushed. Probably also I'll bring a marker and mark the level in the jug, then test by opening the bath sink faucet for a minute to verify the level goes down.
Worst case will be bringing the camper back to the house, hooking up our compressor to the inlet and seeing if we can run air through the showerhead...
One last thought / question on this, which I suspect the answer is going to be "no," but I'll ask anyways.
If the camper is slightly nose-high, would that impact getting the antifreeze to the shower? As I said, I expect not, as it was fine going to all the other fixtures, but better to be sure.
Jay and Kat
/insert Homer Simpson saying "sometimes I'm not too bright"
Winterizing works better if you give the pump time to actually start to fill the lines and suction out from the antifreeze jug...
Yeah, I didn't wait LONG enough for the pump to run. Went back today, new suction hose, set everything up, took of the end of the shower wand so it was just the hose from the wall laying on the shower pan, still nothing. Opened a sink, and uh-oh, nothing? Checked the bottle, didn't appear to have gone down at all, went back in the camper, lets try a different faucet same thing? Went back out to check the bottle and noticed that:
- The fluid level DID look like it was starting to go down
- The pump sound had changed from a sort-of quiet "chugging" to what I normally hear when the pump kicks on, a more "solid" sounding "chug"
Went back in, turned on the shower wand again and a moment later out flows pink for both cold and hot. Re-ran both sinks, same thing.Needless to say, I'm MUCH happier now.
Thank you everyone for your suggestions, because I was starting to worry that somehow the pump was fried after doing the initial round!
Jay and Kat
