Extensively Updated Off-Grid 2023 320S Boondock!
boathealerboathealer Member Posts: 50
For Sale – Extensively Upgraded 2023 NuCamp 320S Boondock - $29,000
This is a very lightly used 2023 T@B 320 with all-new upgrades - everything from cushions to high-end galley to the toilet.  Located on the Gulf coast of Florida near Spring Hill.  Over $35,000 and countless hours of labor invested.  All modifications are new (2025) and are 100% functional.  This is a Boondock model that has been lowered slightly with 14" wheels (vs. 15") to fit under an 8ft exterior height.  No other changes to the stock chassis/suspension has been made.
The primary goal was to have a 100% electric (no propane gas!) off-grid setup that was simple and reliable for warm(er) weather use. I am a retired (30yrs) electrical engineer and did all the upgrade work myself.  Superb off-grid capability – there is no other TAB like it, anywhere.
We are the second owners.  The first owner was an employee at the RV dealership, used it only a few times, and kept it in his garage.  We have since used in on a few trips – one recently 5 weeks long – and keep it up under our raised house out of the elements, with a cover on.
We have run into some financial hiccups and are having to make some big life adjustments.  Unfortunately, and sadly, this is one of them.
I won’t try to describe the basic TAB 320 camper here, there is a ton of information already available on the internet at:
However, nearly all of the upgrades, with lots of photos and lengthy descriptions are shown in a downloadable PDF file here.  Unless specifically referenced there, everything else is per manufacturer. Some of the document's photos copied here.
Partial summary:
Super Off-Grid Electrical System
• High quality Victron system components
• Cerbo GX display panel
• 400W Solar panels
• 600W tow vehicle charging with commercial cable connection/coupler
• 14.4Kw lithium battery bank (1200 Ah!!!)
• Micro Air soft start on air conditioner (Run air off batteries!)
• 2Kw inverter
• 1800W tankless point-of-use water heater (warmer)
• Induction cooktop
• 300/600W electric heater (Run off batteries!)
• Inverter output transfer switch (home backup mode!)
• Full DC and AC system rewiring
• Galley outlet bar and USB chargers
24" Vizio Roku Smart TV
Suction mount external TV antenna
Two super energy-efficient personal fans
Two wireless phone holder chargers
Two new dimmable reading lights with USB charging
Additional portable solar charging with 200W flat folding panels, new inlet connector
Lighted security system with red LED warning light
Lighted under-bed electrical and shoe compartments
Interior cabinet lighting
Overhead vent variable speed control
Low-level nighttime courtesy lighting
"Permanent twins" bed modification allowing extra storage
New high-quality 4" cushions, commercial fabric
Two dinette table setups, small and large with "headboard" storage mount
Custom overhead bin storage
Custom bathroom door storage
Composting toilet remodel
All new galley with more counter space, pull-out faucet, and sink upgrade
Two-stage drinking water filter and separate drinking water faucet
Upgraded removable trash bin
3 outside extensions:
* Brow awning
* Inflatable awning
* Full screen room addition
Rear cargo box and rack
Combination locks on tongue boxes
Custom center tongue box organizer
Swivel trailer jack with large roller wheel
Boondock model lowered with 14" wheels to fit under 8ft exterior height
If you are just a bit geeky, and/or OCD, this is one for you.  No expense was spared in quality of components or installation.  If you like this philosophy and setup, you will not find this complete of a setup anywhere else.
Please contact via private message.
Thanks for looking!
