Tab 400 == Plumbing Diagram - - Draft
As part of my "Tab 400 Most Likely Next Trailer" {since 360 has a cassette and weird kitchen} I'm researching/investigating the Tab 400 systems.
TAB 400 owner observations, comments on the attached PDF file plumbing diagrams are welcome.
Do keep in mind that there has been a lot of variation since the initial 2018 production year . . . goal of diagrams is to capture most common or most current plumbing configuration nüCamp is using. I've tried to show 'connections' that is the T Joints in the correct sequence for a given line. Everything is based on various posted plumbing pictures.
Side Note: One owner reported nüCamp told them the Kitchen CW line had a Check Valve at the sink . . .? . . . perhaps due to the Sink Faucet design?
Any other items like that . . .
nüCamp has above average Build Quality and with the Alde a luxury heating system yet they lack documentation for owners. A few RV Builders do provide greater detail/information. InTech being one of the better examples with Model & Year referenced schematics/diagrams for nearly every trailer they build . . . would be nice if nüCamp did so as well . . .
Not a single Comment, Like, or Agree so far . . .
Is this topic/information of no interest? Or so incorrect No One will Correct it
Confused here.by lack of feedback.
This is a useful project for many, so I too was hoping for some feedback. My suspicion is that a lot of folks have their 400s stored away so not so easy to check the plumbing configuration.
I’m about to take my 400 out so will look around but my 400 does not have the Nautilus. Just a single bypass valve for the Alde water heater.
The schematics are a worthwhile contribution! Thank you! However, it is difficult to comment, in part because that requires transferring a visual inspection, in my case of the Alde compartment and the bottom of the closet, to a diagram representation. That is not so easy to do, at least for me. I can say that the 2018 model, and perhaps all of the pre-Nautilus ones, have three low-point drains near the Alde: cold water, hot water and Alde. I believe the only check valve is to prevent backflow to the fresh water tank, but I don’t know exactly where; I haven’t recognized one yet.0
I am interested as I want to add as much insulation as I can so I can camp in colder weather. Currently I have drained all the lines, blown them out, and added RV antifreeze to the grey and black tanks.
I am interested. I am new to nuCamp and trailers in general. I need to understand where the lines physically are located so I can insulate them so I can use the trailer in colder weather.
And trouble shoot in case of issues. The more I understand about the trailer the more comfortable I will be.Ford F-150 Hybrid
TAB 400
@TabbingEarl said: . . . need to understand where the lines physically are located so I can insulate them so I can use the trailer in colder weather. . . .
It's time to open cabinets and lift up bench seats an good a detailed inspection to identify the piping.
TAB 400 have all the plumbing pipes located in the cabin/heated space. Only the fresh water tank, gray tank, and dump station drain are fully exposed to ambient temperature. Some models do have electric tank heaters.
Since it is impossible to keep the cabin warm while winter towing and it's an extra task to drain everything before towing on a several stop over trip . . . Most owners do not use the TAB water system while winter camping/towing. Bottled water and an anti-freeze mix for flushing toilet with some added to the gray tank as needed works well for most folks.
Is this still a draft in progress? LMK when/if you think it's ready for prime time and I'll post it in the resources library.
@TabbingEarl There are many Forum threads about installing aftermarket tank warmers in various trailers, since many owners want to camp just like you are planning to. A lot depends on exactly what year your 400 is, but the basic design of the trailer (water tanks, etc) have changed little over the years. The market for products that can protect the tanks has expanded a lot over the years. Here is one thread from 2019 where an owner of one of the early 400's has pictures of the fresh water tank in his trailer, and there is a discussion on how to make this sort of thing work.
Here is a group of threads on "tank heaters" that may have some info to help.
I have started adding insulation where I can. I am using the ridged closed foam as it doesn't hold water. I also added insulation to the doors on the outside to the trailer and where the water connection is.
Ford F-150 Hybrid
2026 TAB 400
You note is taken about towing in winter. I was thinking about using a heated hose for city water and keeping the fresh tank empty and antifreeze in the gray and black tanks.
Thanks for your reply0
