I'm selling my 2022 320S Boondock with
upgrades because I need something slightly larger. I am the second
owner. Oregon registration is good through November 2026.
My trailer is upgraded with features to support lengthy boondocking.
Standard Feature Highlights:
- Cassette toilet. Much better for boondocking in my view
- Wet bath with sink
- Kitchen sink and two burner propane stove
- Dual pane acrylic windows
- Torsion axle
- 3.1 cu-ft 12V refrigerator
- Outside shower
- Alde 3020 hydronic heat and hot water (Electric or propane)
- Elwell Air8 air conditioner (shore power only)
- Original Rainer Apex 235/75R15 tires with January 2022 date code (0222). The tires are in very good condition.
- Full-size 15" tongue-mounted spare
- Front storage tub
- Nautilus water management system
- Yakima rack system with Yakima roof-mount basket
- 130W Sunflare flexible solar panel.
- Front storage tub
- Microwave oven (shore power only)
- WFCO WF-8735-AD power center (lithium aware)
- Dry weight: 1993 lbs
- Exterior Length: 15'3"
- Exterior Width: 6'8"
- Exterior Height: 7'8"
- Interior Height: 69"
Upgrades:
- 300Ah
Renogy Core Mini lithium battery mounted in the passenger side rear
compartment next to the AC unit. This battery has temperature protection
but is not heated. For that reason, it is mounted inside the cabin.
This freed up space in the front storage tub for other things.
- Additional
120W Renogy Shadowflex rigid solar panel (for a total of 250W) with
separate Victron Smart Solar MPPT 75/15 charge controller. The wiring
and MPPT controller are sized to support up to a 200W Renogy Shadowflex
solar panel which would bring the total up to 330W.
- Victron Smart Shunt 300A for battery management
- Battery charge port for Nuco Genius 5 battery charger for battery maintenance
- New
cushions with upgraded fabric and foam throughout. Greatly improved the
bed comfort while giving a rich look (see photo). I have close to a
yard of the fabric leftover if you want to make pillows or additional
cushions.
- SnapPads on all four stabilizer jacks. Really helps on gravel surfaces.
- Rear compartment organizers
- Bathroom door organizer
- McGard wheel locks on both wheels and spare
- Mopeka wireless propane level sensor
- Key rack by the door
- Custom-fit butcher block cutting board over the sink
- Comes with Lego leveling blocks, wheel chucks, water supply hose, 30A power cord and Nuco Genius 5 battery charger.
The
glycol in the Alde heating system was professionally replaced in
January 2025. The wheel bearings were professionally repacked at the
same time.
I've been really impressed with how well the Renogy
Shadowflex solar panel performs compared to the factory 130W Sunflare
flexible panel on the front. If I were keeping the trailer, I would
remove the Yakima basket from the rack and replace the 125W Renogy
Shadowflex panel with a 200W Renogy Shadowflex panel. This is a bolt-on
change; no wiring changes needed. It would also be easy to add a port
for a solar suitcase but that would require some additional wiring. It
would be fairly easy to add the display panel for the Victron BMV-712
battery manager, but I find the Victron app to be sufficient.
I've towed this trailer with both my VW ID.4 EV and my VW Touareg TDI. Easy to tow.
The
trailer has been stored indoors since I purchased it about a year ago. I
need 24 hours notice to have it brought out of storage for viewing.
I'm asking $23,500. View and pickup at the storage facility in Gladstone, OR. I can give prospective buyers a virtual walkthrough via FaceTime or Zoom. DM with questions or to setup a viewing.
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
