Locking the door with key
I am unable to lock my 2026 T@B 360 camper door using the key. In order to lock the door when leaving the camper, I need to move the level on the inside of the door up to the locked position and then shut the door. A clockwise turn of the key unlocks the door, but a counterclockwise turn of the key is not able to unlock the door. Any one else with this issue?
While no direct experience with the TAB 360 . . .
Frequently, RV Door Locking issues are caused by the Door Latches not being in alignment with the door Frame Strike Plate'18 320 S, pitched axle, 3020HE; PNW based
As a follow up to MuttonChops description, it seems from your description that the dead bolt may be hitting the striker plate while trying tp lock with the key, but when unlocking the key is able to pull the dead bolt out. By lifting the door when inside you correct for this slight misalignment. A small adjustment of the striker plate down or a bit of filing if adjustment isn't possible should correct the problem. A bit of lifting the door while locking with the key may also work.0
On my 2025 320 I have noticed that the door will close completely, click, and be latched, but if I give it a gentle push from the outside (or pull from the inside) it will click again and be even "more latched" than it was before (by about 1/4 of an inch). Try pushing on the door before you lock it with the key and see if it doesn't pop into place even more.2025 Tab 320 S BD2024 Nissan Frontier1
Had the same headache with my 2025 model until I realized the striker plate was just a hair too high. I loosened the screws, pulled the plate down a few millimeters, and retightened, then the key turned smooth as butter. Also, if the door never fully clicks, give the handle a gentle push while turning the key. That little nudge solved it for me. By the way, I work in building maintenance and we use fire retardant doors on every project, and I can tell you from experience that a proper strike plate alignment makes all the difference, even on those heavy solid-core units. Try the plate adjustment first before messing with filing anything.
