Keder rail anchor
Does anyone have a photo or video of how to use a Keder rail anchor in our T@b rails? I just bought a Moonshade and want to use their 2 point anchor system using the Keder. But I can't figure out how I will get the anchor ring attached to its base in such a narrow space. TIA!
I don't have a picture but if you look at either end of there Keder rail you will notice that there is an area where the rail is wider, this is where you would slide a keder, or whatever device you have that uses the rail
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0 -
Looks too large or is too large? If it's a std, 8mm (I think), then it should fit, if not you need to get another anchor
I don't know yet - I haven't received it from MoonShade. I just reverted to my prior plan to use their vacuum/suction cups. I was just afraid the awning would cover the solar panels. Hopefully I can use the suction cups successfully. If not, I will order the 8mm anchors and hope I can get those to work. They are only $25 more.
well I think it will fit, you can’t judge from the picture
webers3 …Thanks so much for your input!
Not my idea but another Tab’er used this for their keder rail. I cannot figure out how to copy the link, but if you type this in your favorite search Engine you should find numerous examples
Luomorgo 23mm/0.91 inch Length White Plastic Curtain Track Carrier Glide Rollers 50Pcs2020 TAB 320 U
TV 2025 Telluride X Type0 -
We have the Moonshade that we mount using the keder rail anchors and love it. It takes just a few minutes to set up or take down. I also have a third anchor right in the middle that I use to attach a short cord to and clip it on the loop that is on the Moonshade. This keeps the middle higher than the sides, making rain run to the side rather than down the side of the trailer. I skip this step if there’s no rain in the forecast.
Here is the shade in use at Chaco Canyon.
Edit: Once the anchors are in place there’s no need to remove them. They’re their all the time and always ready.2021 320S BD
2017 F-150
Coeur d'Alene, Idaho1
