Perfect replacement unit for Jensen JWM22 Stereo
Greetings. I wanted to let everyone know the Boss BV6860BH head unit is a direct perfect replacement for the Jensen JWM22, including the screw holes. The LCD went bad on my Jensen stereo in my 2021 Tab320, probably due to prolonged minus 30 temps, and I was happy when I went to install this $50 Boss unit and it popped right in and perfectly aligned. Seems to be a nicer unit than the Jensen.
    pthomas745 Administrator, Moderator Posts: 4,704
    There are as many complaints about the Jensen head units then there are about any other part of the trailer. Replacing the unit is the solution.
    So, this one popped right in? Have you tried the HDMI passthrough there on the front of the unit?
  • Vincent
    Vincent Member Posts: 7
    Was the wiring connector a match or did you have to splice it?
  • Ablezerosix
    Ablezerosix Member Posts: 18
    edited August 27
  • valkraider
    valkraider Member Posts: 61
    We never use the head unit.
    When we use the TV I just connect to it directly via a separate HDMI cable. Usually connected to an iPhone to watch streaming, or to our mini video game consoles…
    But I have been thinking about ripping out the head unit, and replacing it with a little cubby that has a USBC power plug so we can plug in a phone while watching TV.
    I would probably also add something like this hooked to the speakers just in case we wanted to use them:
    https://www.amazon.com/dp/B0DGTK6P4P
  • EPOD1
    EPOD1 Member Posts: 42
    I no longer have the Jensen TV, I updated that with a slightly larger OLED and love it. The Jensen JWM22 is still there and I do use that as a Bluetooth sound system, however the sound is terrible and I would like to upgrade that.
    The whole panel above the fridge is about to get a do over and that would include opening the section and replacing the the panel with something else.
    Right now the HMI for the Victron Cerbo GX is mounted next to the Jensen. I am looking for a purpose built multi zone head unit that will support Bluetooth and wired inputs to replace the Jensen.
    My inputs for the Starlink Mini are coming in from the outside panel that is accessible in the space behind the Jensen. I might also include the front indicators of the small router/switch that might be in the front panel.
    It would be nice to find the same format footprint as the JWM22.
    Please keep posting what you find!
    Thank you.
  • EPOD1
    So far I have come up with this:
    Kenwood KMR-XM500
    It has more functions, built for marine use, newer product, 19X4Watts vs. 6X4Watts, fits in the same hole and it is Kenwood.
    I am not sold yet and the idea of putting something larger in there is a thought. I am not looking for louder sound, but instead clear, clean sound and better, more modern integration with audio devices.
  • SLJ
    SLJ Member Posts: 668
    Kenwood's inputs are all on the back so it wouldn't work for me as my music library is on thumb drives. I currently have a Furrion (Lippert) cube stereo that the only thing that bugs me is it doesn't remember the last source or song after powering it off. When I want high quality audio I use a Bose Bluetooth speaker.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • bjn2
    bjn2 Member Posts: 124
    Utah-based
    2023 T@B 320 S Boondock
  • EPOD1
    Thanks for the feedback, still looking here.
    Kenwood is off the list….
  • EPOD1
    So far the format is odd, but a lot of the marine units will fit, which are made to fit into round gauge holes on a console.
    This one looks interesting and it's made by Garmin: Garmin Fusion Apollo MS-RA670
    The Apollo has a USB input on the back and I could easily make a flange mount USB int the front panel. So this one is in the running.
  • rydfree
    rydfree Member Posts: 44
    edited September 9
    For headunits with rear leads you can buy panel mount extensions such as this to place anywhere.
    https://www.amazon.com/BATIGE-USB3-0-Extension-Waterproof
  • SLJ
    But then it's not a direct swap.
    Would be interested in how the Boss BV6860BH works as I've read some reviews that weren't happy with the sound quality.
    2025 Ford Ranger
  • EPOD1
    When it comes to sound quality.
    You get what you pay for.
