Best Water Filter Pitcher in 2026: Top Picks for Clean & Great-Tasting Water
I researched about the best water filter pitcher for the past few days because I need one for clean and better-tasting drinking water at home. I read reviews, and they are recommending these two as the best:
Clearly Filtered Water Filter Pitcher, 10 Cup
https://www.amazon.com/Clearly-Filtered-Contaminants-Fluoride-Microplastics/dp/B0DFC22BHT
DREO Reverse Osmosis Water Filter System
https://www.amazon.com/DREO-Reverse-Osmosis-Countertop-Filtration/dp/B0GHNXHLHS/
However, I am having trouble deciding which one would best suit my needs and need your expert advice. I mainly want a reliable filter with good filtration and easy everyday use. So which one should I buy? Any recommendation will be appreciated.
Thanks in advance!
We have used the Epic water filters both countertop and bottles, for a few years now and have had no concerns. Very good quality and good tasting water. Filters are certified and take out all the bad stuff. We have used the bottle filters when traveling and no issues with water filtered thru these filters.
Also not as pricey as your links above
There is a lot of great info and comparison reviews at this site Clearly Filtered is their top pitcher pick. It would not be mine due to the method of priming the filter. I would choose an Epic Nano XP for traveling and filling water from unknown sources. I love the taste of RO water, but even the tabletop models require some counter space "in the camper". Are you truly asking about a solution for home? If it's for home use are you on well water or municipal water? If municiple, I would get a water quality report from the city/water supplier then let that report dictate a picther, or a gravity system like Berkery or it's clones, undersink RO or a distiller. RO and distiller remove minerals too, which may or may not be what you want.
ps: I would also learn about NSF ratings to help separate facts from the seller "hype'd claims"
2025 T@B 320 S Boondock Black Canyon - “Another T@Bventure”
2024 Jeep Grand Cherokee Overland
we have used the clearly filtered pitcher for several years now and it works out great. We use it at home and just bring the pitcher with us when we travel. It definitely improves the taste of almost any water.
2019 Honda Ridgeline RTL TV
Poughquag, NY0
