What is your tow vehicle?
crobo
crobo Member Posts: 25
Bought a 2024 Tab 320 Black Canyon this year. I'm going to buy a TV in the Spring, so starting some research now.
Would like to buy something that could be my everyday driver also. Not really interested in a pick-up, but if I have to I have to. A Subaru would be nice, but I don't think it would be a stress free tow. Looking at something that tows 5000 pounds.
I was looking at the Honda Passport, but the payload is under 1000 pounds. Seems a little light to me, but don't have much experience towing. I have read some comments of people towing with it and say it is fine.
So what do y'all tow with? Anything you've learn while towing with your set up?
  • Horigan
    Horigan Member Posts: 927
    2025 Toyota Highlander 2.4L Turbo. Love it. Plenty of torque at high altitudes, even with a 400.
    Rich
    2019 T@b 400
    Bellingham WA
  • Grumpy_G
    Grumpy_G Member Posts: 789
    I've towed the T@b with a Ram 2500 and a Jeep Gladiator. The Ram is obviously overkill but also makes for a more relaxed towing experience. The main complaint about the Gladiator is that the engine does not have a lot of grunt so it tends to run high in the rev range unless on flat ground with little wind. That is the same with the Passport or other naturally aspirated sub 4 liter engines. It works fine though and the manufacturers did validate the towing capacity but at as a rule of thumb you don't want to max out the towing capacity on smaller vehicles.
    The V8s and turbocharged engines tend to do better towing at the expense of lower MPG in daily driving. It comes down to how often and what distances you're going to tow. 5-6 times 2-3 hours away pretty much anything will do, multi week trips across the country you might want to gear the vehicle more towards towing use.
    A friend of mine has a Passport Trailsport and it did tow a T@b and now a lightly larger single axle trailer just fine. Another friend tows his T@b with a RAV4 pretty long distances.
  • bandr1tnj
    bandr1tnj Member Posts: 8
    A few of us on this forum tow with an EV if that’s of any interest. I’ve towed my 2019 Tab400 with both the Rivian R1S and R1T. I get about 200mi per charge which suits me just fine.
    2019 T@B 400 + 2022 Rivian R1T
  • RTWCTS
    RTWCTS Member Posts: 214
    We are a +1 on towing a 400 with an EV.
    Homeport - Virginia Beach, VA
  • AnOldUR
    AnOldUR Member Posts: 1,762
    We've towed a 320 T@B about 70K miles with a two door Wrangler.
    Works fine and we have no plans or desire to change, but would I recommend it?
    No. 😉
  • SLJ
    SLJ Member Posts: 668
    Started towing our 320s with a Bronco Sport but it was close to it's max towing in the hills so switched to a Ford Maverick with the 4K tow package. Towed the 320s great with no problems. Wife wanted another even larger camper for the grand kids and dogs so switched to the Ford Ranger w/7.5K tow package. The Ranger will tow anything with a single axle anywhere.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • KaomRuns
    KaomRuns Member Posts: 26
    We started out towing with a Jeep 4xE Wrangler. Did the job and only real complaint was trying to open the tailgate while hooked up because of the spare tire on back. Traded in and got a Nissan Frontier Pro-X. Didn't need the 4x4 and got plenty of payload and can tow 6900 lbs. Love the 6 cylinder engine and happy about everything straight from the factory. Only gripe was needing to install an aftermarket brake controller. It was easy enough though as the Nissan was pre-wired for it. Toward was plug and play. Would 100% buy it again. Got a tent for the bed when unexpected friends or extra family decide to tag along.
  • ckjs
    ckjs Member Posts: 144
    Would like to buy something that could be my everyday driver also. Not really interested in a pick-up, but if I have to I have to. A Subaru would be nice, but I don't think it would be a stress free tow. Looking at something that tows 5000 pounds…
    The Ascent can handle that. Our Outback XT is rated for 3500 pounds and does fine towing our 2018 CSS (2000 lbs dry) even when all loaded up for month long trips.
  • Mickerly
    Mickerly Member Posts: 517
    We pulled our 320CS-S with an Outback XT for four years. It worked great. We upgraded to the Ascent. It worked better in some ways. The Ascent is rated for 5000lb. It's wired from the factory (with the hitch option) for both 7 and 4 pin connection and there is a plug for a brake controller under the dash. The Ascent has trailer stabilization too.
    We pull a 17ft Casita now. It is 1000lb heavier, 14in taller, and 6in wider than the '320. The Ascent does great. We have done some mountain driving, it has plenty of power. Without the trailer, it is my work commuting car and family bus.
    I'm not sure where you are. Most of the western states have a towing speed limit of 55mph. At 55 with the Casita we get over 20mpg on level ground and clam winds. At 67 it drops to 16mpg. The '320 is not as aerodynamic as the Casita, your milage may be different.
    2018 320CS-S
    "Just Enough"
