Suitcase solar panel set up
I have a 2023 Tab 400 with an sae connector installed on the outside. I am looking for a 20-30 foot cable to run from the SAE connector to a victron 75/15 controller that is then connected to a renogy 200w solar panel (no onboard controller). Anyone have a similar set up and can recommend a cable?
Thanks
Brian
Have you checked with Renogy ?
The heavier gauge the better. I carry 20' and a 10' long, 10 gauge. solar cables. I would only use a SAE connector at the camper end using short SAE to MC4 solar connector adapter cable. Here in the Northeast we have lots of shade so it can be a challenge to get the portable panel out in the direct sun sometimes.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
Brand: Bateria Power Solar Cable available in many lengths and multiple gauge wire AWG. I would not get anything higher 10AWG when you want to run a 20 to 30 foot extension for solar.
2023 TAB 320 SS BD
2025 Aviator
