Suitcase solar panel set up
uncleb0919
uncleb0919 Member Posts: 3
I have a 2023 Tab 400 with an sae connector installed on the outside. I am looking for a 20-30 foot cable to run from the SAE connector to a victron 75/15 controller that is then connected to a renogy 200w solar panel (no onboard controller). Anyone have a similar set up and can recommend a cable?
Thanks
Brian
  • Okpete
    Okpete Member Posts: 45
    Have you checked with Renogy ?
  • SLJ
    SLJ Member Posts: 669
    The heavier gauge the better. I carry 20' and a 10' long, 10 gauge. solar cables. I would only use a SAE connector at the camper end using short SAE to MC4 solar connector adapter cable. Here in the Northeast we have lots of shade so it can be a challenge to get the portable panel out in the direct sun sometimes.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Mariea
    Mariea Member Posts: 8
    Brand: Bateria Power Solar Cable available in many lengths and multiple gauge wire AWG. I would not get anything higher 10AWG when you want to run a 20 to 30 foot extension for solar.
    2023 TAB 320 SS BD
    2025 Aviator
