How to level the FIRST time?
Photomom
Member Posts: 2,217
Okay, I've added the stick on levels to my Amazon wish list and understand how to use them to level the trailer.
Now, what do you do BEFORE you stick them on? What is the best procedure to use to get the trailer perfectly level so that you can stick the levels on straight?
A long level that builders use - I think we had a 24 or 36 inch level - across on the inside floor wheel to wheel and then long ways in the middle of the T@b. Measure twice (ok a zillion times) and be sure before sticking the little ones on.
PS - we use Andersen levelers so we could do "infinite" increments to get the side to side really level.2015 T@b S Max | 2015 Jeep Wrangler Unlimited | was PHX East Valley, now Dallas!0 -
It helps to stick them along flat edges like the window or on the side by the vent.
Yep, find a nice level spot and do what bgualtieri recommends. Since the fridge is sensitive to left/right leveling, I put a level on the fridge frame. Have found that you get slightly different readings between floor, counter top, and fridge frame. Might just be a quarter bubble. I adjust for fridge frame.0
Once I am set up and level with the bubble gauges, I find that I can adjust the level of the fridge (that quarter bubble) just by using the stabilizer jacks - tighten one side a little more than the other.1
AgreedPXLated said:Yep, find a nice level spot and do what bgualtieri recommends. Since the fridge is sensitive to left/right leveling, I put a level on the fridge frame. Have found that you get slightly different readings between floor, counter top, and fridge frame. Might just be a quarter bubble. I adjust for fridge frame.
Yeah. We were trying to level across the floor over the axel to get an accurate side to side level. I guess the fridge is the important piece but we didn't think of that.2015 T@b S Max | 2015 Jeep Wrangler Unlimited | was PHX East Valley, now Dallas!0
We concentrate on the fridge but if you're using the air conditioner, it might be better to make sure that drains properly at the expense of the fridge.0
I have never had a problem if it is level. I don't think there is a vast enough difference between dolor, counter, or fridge to affect the fridge... of course as you satay, your mileage may vary.PXLated said:We concentrate on the fridge but if you're using the air conditioner, it might be better to make sure that drains properly at the expense of the fridge.
The only 2 times in had problems were when I really didn't bother to level, at all.
Just saying that since the fridge level may not match the frame level or air conditioner level, if you level to the fridge or the frame it may mean your drip pan might not drain properly.0
We bought a nice level at the Dollar Tree for a buck. This works great and is something we stow in the t@b underbelly.0
Nice level app available for smart phone for free on play store. Works great but needs calibration when first used. I find myself always using it all over. Made a great hit at Dr. office leveling pictures while waiting.2
I used our iPhone's level to get an approximate degree of incline of our driveway. The level functionality was built in-select the compass in extras and slide to the left to get the level. Didn't need terribly accurate info for my driveway dreams, just close enough.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner3 -
Compass app is separate for android. I also use that all the time; to find my way from the refrigerator to the bathroom (due east right now).2
Following up to say that we never did put the stick on levels on. I don't think we've ever had the T@B in a level place! I bought a one foot carpenter's level and just use it on the floor in front of the fridge. It is stored behind the door next to the fire extinguisher where it is easy to grab when setting up.John and Henrietta, Late 2016 T@B S Max in Western New York3
