I read the Powerpoint slide deck, read the posts, called the dealer, winterized my trailer and I'm still wondering if I've done this right.
I don't have an air compressor, so I opened all the valves to drain everything. Right there I have my first issue. Only about two cups of water came out of the Alde water heater. That seems strange. Seems like it should have been 1 - 2 gallons.
With all valves open, I ran the water pump to get as much water out of the system as possible. Drain. Next, I set the valves to "winter" mode as shown in the slide deck and put two gallons of pink stuff in the fresh water tank. Then I ran the outdoor shower and the inside faucet until pink stuff came out everywhere.
The dealer said this was the right thing to do, even though I don't have an air compressor. He also said not to worry about putting pink stuff in the city water connection as the pink stuff will back up to the valve.
Three questions:
1) Why only two cups of water draining out of the Alde hot water heater? (I was on a level surface)
2) Why do I need to use the air compressor if I"m going to turn around and put pink stuff in?
3) Am I just being paranoid or have I missed something?
Thanks,
~ Joe
2015 Max U Outback; 2011 Chevy Silverado 4X4; Austin, Tx
