Battery not charging
I bought a used t@b and have been figuring things out as I go. I am brand new to all of this so with that said here is my problem/question. I believe my battery should be charging when I plug the t@b in to the garage. Nothing is happening, but I took a car battery charger and plugged it inside the trailer and hooked it to the battery. Everything works just fine when I do that. Shouldn't the trailer be charging the battery when it gets plugged in? Any ideas where to start if it is? I'm not going to fix that myself but I would like to give my brother a little heads up when I bring it to him for some of the repairs.
    Check the fuse box for starters. There are a couple of fuses that pertain to charging in there.
    Also check the in-line fuse on the wire at the battery.
  • NormfunNormfun Member Posts: 285
    The short answer is yes it should charge the battery while plugged in. Things to check
    Does the outlet have power
    Are the fuses and breakers in the T@b good
    Is there a hidden battery disconnect switch somewhere
    Is the fuse on the battery good (30 amp)
    What year is your T@b?
    Oh and welcome aboard!!
