Norcold Removal
@RZBug: Thanks for the tips about removal/installation and wiring. Yes, I'll be removing the gas line (with all power turned off, battery disconnected and still respectful and careful.) I've worked with gas lines before and I want to again someday in the future if the need arises.
I expect that there is going to be some woodworking involved to build a base and fit the sides. It's gotta look good and be rock solid in the end.
Did you add additional insulation around the sides of the new unit? I figure it can't hurt if I can do it without blocking anything important.Rich, 2013 T@B, Front Range, Colorado0 -
I did not add any insulation. The unit was a pretty tight fit on the sides, which is the only place I could have added any because the coils in back need to be left uncovered. I considered gluing some thin rubber padding to the bottom of the feet to dampen vibration, but did not do so in the end. While I had the unit out, I looked everywhere for anything that might vibrate and rattle, including in the adjoining cabinets. I did add some sheets of rubberized material where lines, gas and electric, were routed through the cabinets because some were rubbing a little. You can use the palm of your hand and lightly tap the cabinets and listen for any rattles, then chase them down and fix them. And, you can do this to the unit itself before installing. I found a couple of wire ties that were rattling against the coils in the old unit by doing this. If you add insulation, just be cautious about blocking any needed air circulation. Actually, I'm not sure any additional is needed because the unit is pretty well insulated.
I did have to add a thin piece of trim across the top because the plastic trim on the new unit did not cover up the old screw holes. Sounds like you've got it under control. I hope everything goes well. BTW, you know patience is a virtue.
I always get in too big a hurry when I tackle a job like this. 0 -
Good luck with your mod! I was going to suggest just using the fridge as storage. On one of my other messageboards, a woman was storing sewing machines in a fridge. Sewing machine collectors can be a bit nuts.0
