Can dimmer switches be installed on the 12 volt LED lights?
tabhappytabhappy Member Posts: 40
Has anyone replaced a D/C switch to a dimmer for the LED lights?
   Dena & Jim  Plano, Texas
Became Tabbers Oct. 24, 2015
    @Michigan_Mikedid you do this? I think I remember someone saying they had.
  • tabhappytabhappy Member Posts: 40
    I didn't, but would like to know how.  I'll keep digging.
    I hate bright lights - search for light dimmers threads - I made inserts to dim the suckers. Can remove when I want or need brighter - inserts are nothing more than milky disks cut from a milk carton.
    I opted for the smaller lights used in the T@G trailer units and shown in the photo.  I mounted a light in the back corners of the trailer, beneath the cabinets in my Max S unit.  These lights are in addition to the front mounted lights on the cabinets that I use for lighting up the interior.  The smaller under cabinet light has a solid clear lens, provides a nice soft reading light and when you push the button in again the light changes to blue.  Both lights look nice in the light blue light cast inside the trailer and are like a mood light and I leave them on when away from the trailer.  If you are interested you should call Elsie at the factory or email her and inquire about them to see if they are still available.  I had these lights for a while and intended to use them in my Silver Shadow, but like them in the T@B.
    There are 12 volt dimmers available and you can buy them on Amazon.  I had spoken to an RV supplier and he said that they were available, but he never got back to me as I'd mentioned that people in the forum areas were interested.
    Check these out...  There are many of these out there and Google is your friend!
    Wall Mounted Touch Controller
    Adjustable Dimmer
    Image result for PWM Dimming Controller For LED Lights or Ribbon 12 Volt 8 Amp
    Thanks for the info although I have two of these 12V RV switches, one for the front door light and the inside light.....
    Adding this to my list of planned mods...
    @tabhappy, where did you get your switches?
    Search LED dimmer switch 12 volt for RV on Ebay, or the manufacturer...
    That one looks really nice, like it belongs in the T@B!
    I took the porch light apart and converted it to an amber LED light so this will limit the bug attraction and makes a comfortable light outdoors that I can leave on and still be able to function and find my trailer in the dark.
    ooooowa, I want to do that. We did figure out the dimmer switch installation though...
    Nice install - it looks like they were meant to be for your T@b!
    I put a bunch of dimmers in my house and realized alter, I never use them. If I could dim anything, it would be the reading lights. Instead, I opt for eith my dimmable lantern or the soft fair lights I have.
    Like you Jenn, once set to my desired brightness, I never touched them again. That's why my little disk inserts are working out so well. Once I found the disc density that gave me the right brightness I was set. Haven't touched them since. I also cut discs out of a photographic (stage lighting) gel sheet to warm the color up a little - got that warm old log cabin style light.
    Yeah, you're probably right about not adjusting them after they are set where I want them. We've only camped in it once and I didn't like getting blasted with the LED's.  I wish I thought of the filter thing instead, that would have been fine.....but what's done is done!
