Ok, I'm at Dangerfield State Park in TX. It is getting pretty chilly, so I turned on the heat. I didn't hear the "dripping" sound I usually hear. I checked the temp settings (set to "5" now), fuse box, glass fuse inside the Alde panel, and they all seemed okay. I found out water heater is working and producing pretty hot water as usual. Now, the room temperature is 65F. I tried both electric and gas (and both). When I turn it on, it gives me a "click" sound, but it is probably for the water heater. Earlier, two hours after I turn on the heat, it finally started making the usual motor (pump?) and dripping sound and stopped in about 10 seconds. Is my thermostat broken?
0 ·
Thermostat could be broken but there isn't much to it so not much to break.
Thanks for the suggestion, though.
Installing a new analog is pretty easy. The digital is a little more involved and takes a Verna type :-)
It was trying to start. I heard the clicking sound and dripping sound for about 10 seconds several times before I fell asleep.
I have sent a message to the factory through their contact form, but I haven't received anything back yet (I did receive the auto reply message from the system). It did work next day, so I will see how it goes. I will msg you if I don't hear anything from them.
Jiro
Thanks Ed and everyone on the forum!
It started working during the night and worked whole day 2nd day the last time. I'll see how it goes this time...
