I ran across on this site where someone did a great job hooking the black & gray dumps together. Can't find it again. How did he get the black plastic connectors lose? Thanks Art
Bob, that's what I thought but cutting off the black drain would not leave enough end to cement another fitting on. What I would like to know is how he did it. I did a search but could not find it again. He had 3 great photos but not much more. Sure wish I had put it in favorite places so I could find it again. Thanks for your reply Bob.
Thanks Bob, I have done a LOT of PVC plumbing but never in so small a space where the black tank exits so I will have to be careful. The black tank fittings are butting up against each other. No clear run to cement a coupler to. The gray tank has a straight long piece that can be cut & re cemented anywhere along it. That one is a piece of cake.
it's in the forum somewere. It's look like they unbolted it apart on the large dump and on small side cut pipe use rubber hose with clamps
Central,Fl
2015 T@B Max-S
http://tab-rv.vanillaforums.com/discussion/1535/combining-gray-and-black-water-dump-valve-to-one-central-discharge/p1
Central,Fl
2015 T@B Max-S
