PERMANENT Y-Connection
gulfarea
Member Posts: 524
I ran across on this site where someone did a great job hooking the black & gray dumps together. Can't find it again. How did he get the black plastic connectors lose? Thanks Art
2019 TaB 320 S Boondock Edge
What Bob says - When I wiped out my gray water valve it was basically saw it off and start over.
Bob, that's what I thought but cutting off the black drain would not leave enough end to cement another fitting on. What I would like to know is how he did it. I did a search but could not find it again. He had 3 great photos but not much more. Sure wish I had put it in favorite places so I could find it again. Thanks for your reply Bob.2019 TaB 320 S Boondock Edge
it's in the forum somewere. It's look like they unbolted it apart on the large dump and on small side cut pipe use rubber hose with clampsTony D
Central,Fl
2015 T@B Max-S -
Tony, Now we are getting closer, Thanks Art2019 TaB 320 S Boondock Edge
Thanks Bob, I have done a LOT of PVC plumbing but never in so small a space where the black tank exits so I will have to be careful. The black tank fittings are butting up against each other. No clear run to cement a coupler to. The gray tank has a straight long piece that can be cut & re cemented anywhere along it. That one is a piece of cake.2019 TaB 320 S Boondock Edge
Found it for you in search function. Sorry don't know how to hyperlink
http://tab-rv.vanillaforums.com/discussion/1535/combining-gray-and-black-water-dump-valve-to-one-central-discharge/p1
Tony D
Central,Fl
2015 T@B Max-S -
Thats the one I was looking for, wish he had the parts list Thanks Tony2019 TaB 320 S Boondock Edge
- 919 Introductions
- 74 Teardrop Groups & Links
