My crossbar hanging down also
gulfarea
Member Posts: 524
As I was starting to set up my dump valves from two outlets to one, I noticed the crossbar under the propane tank just dangling down. Someone else on this site also mentioned this. It also holds the 1-1/2 gray drain pipe which was still holding the crossbar up. As I no longer need the 1-1/2 drain going forward I just re-secured the crossbar with grade 8 bolts, ON THE BOTTOM flat area of the trailer frame not on the very thin top edge of the trailer frame like the factory had done. My CS-S is brand new so I suggest if you have the S models you check this. Art
2019 TaB 320 S Boondock Edge
