Jensen on/off switch?
2»
  • CanadianTabber
    CanadianTabber Member Posts: 148
    Dudlee said:
    . . .  installed the switch in the charger outlet faceplate.
    Very nice & clean.
    Wish I had thought of that.
    Mine is not so . . . .
    Is that a pushbutton switch on the usb outset?..I want to shut mine off too and this looks very viable.
    2021 Tab 320s Boondock-2016 Toyota Venza V6
    Toronto, Canada
  • tomtek
    tomtek Member Posts: 48
    I added this switch and it has done very well cutting back battery usage.
    2009 Dutchman TQ - Sold
    2021 CS-S - Enjoying the new layout
    2011 Outback 3.6r
  • TABNewbies
    TABNewbies Member Posts: 92
    And my take on this one with also an additional cigarette lighter socket while working in that void area there for a simple battery monitor
    2021 T@B 400 BD T@bitha with 2016 Highlander
    Juliet and Andy in Massachusetts
  • aphillips
    aphillips Member Posts: 46
    @TABNewbies and @tomtek Looking at lots of mods as we wrap up our first 2 week long road trip. :) Was this pretty easy to do? I would really like to turn the Jensen off, but we are not wiring experts.
    2022 Tab 400 Boondock
    2024 Toyota Tundra SR5
  • kevmon
    kevmon Member Posts: 34
    This looks great. I was going to add a switch, but we never use the Jensen or TV, so I just pulled the fuse. I'll eventually add a simple rocker switch.
    2023 T@B 320
  • elbolillo
    elbolillo Member Posts: 575
    I installed my rocker switch in the cubby at the head of the bed.
  • SLJ
    SLJ Member Posts: 666
    edited July 2024
    My T@B was lit up at night as almost nothing was completely off. I ran everything to this switch panel I added next to the Jensen in my '21 320. Now nothing glows at night. (L to R): Outside USB ports (I added), Inside USB ports, Jensen Stereo, TV, Blu-Ray/DVD player.  I replaced the round ceiling and bathroom lights that glowed even when off with these dimmable exact replacements that are off when switched off: https://amzn.to/3XWh7HG
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Bill&Suze
    Bill&Suze Member Posts: 179
    I have the '24 T@B 400. The Jensen control panel has a perimeter bezel that I assume needs to be pried off to be able to remove the control unit to access wiring. The bezel edges are tight to the wall paneling and it doesn't budge a bit with fingernail pressure. I can't even get fingernails started under the edges. How are people safely removing it without marring the wall? Does the unit actually need to be removed from behind in the wall cavity? That would be quite a project to gain access.
    Susan & Bill, Yarmouth, Maine
    2024 Kia EV9
  • tomtek
    @aphillips
    I felt is was easy but I am an electronics person for hobby and work.
    2011 Outback 3.6r
  • Marceline
    Marceline Member Posts: 1,779
    Are you trying to save parasitic battery drain or do you just want the lights on the stereo to go off? If it's the latter you can just read the manual to learn how to turn the light off.
  • Bill&Suze
    To prevent parasitic drain, which I confirmed by watching the VictronConnect app while the Jensen panel was powered, and then after pulling its fuse. There's an observable drop in battery amp output when power to the Jensen panel is cut.
    2024 Kia EV9
