Jensen on/off switch?
Is that a pushbutton switch on the usb outset?..I want to shut mine off too and this looks very viable.MuttonChops said:Dudlee said:. . . installed the switch in the charger outlet faceplate.
Very nice & clean.
Wish I had thought of that.
Mine is not so . . . .
Toronto, Canada0 -
I added this switch and it has done very well cutting back battery usage.
2009 Dutchman TQ - Sold
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r0 -
And my take on this one with also an additional cigarette lighter socket while working in that void area there for a simple battery monitor
2021 T@B 400 BD T@bitha with 2016 Highlander
Juliet and Andy in Massachusetts2 -
@TABNewbies and @tomtek Looking at lots of mods as we wrap up our first 2 week long road trip.
Was this pretty easy to do? I would really like to turn the Jensen off, but we are not wiring experts. 2022 Tab 400 Boondock
2024 Toyota Tundra SR50 -
This looks great. I was going to add a switch, but we never use the Jensen or TV, so I just pulled the fuse. I'll eventually add a simple rocker switch.2023 T@B 320
2021 Jeep Grand Cherokee0 -
I installed my rocker switch in the cubby at the head of the bed.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia2 -
My T@B was lit up at night as almost nothing was completely off. I ran everything to this switch panel I added next to the Jensen in my '21 320. Now nothing glows at night. (L to R): Outside USB ports (I added), Inside USB ports, Jensen Stereo, TV, Blu-Ray/DVD player. I replaced the round ceiling and bathroom lights that glowed even when off with these dimmable exact replacements that are off when switched off: https://amzn.to/3XWh7HG
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York2 -
I have the '24 T@B 400. The Jensen control panel has a perimeter bezel that I assume needs to be pried off to be able to remove the control unit to access wiring. The bezel edges are tight to the wall paneling and it doesn't budge a bit with fingernail pressure. I can't even get fingernails started under the edges. How are people safely removing it without marring the wall? Does the unit actually need to be removed from behind in the wall cavity? That would be quite a project to gain access.Susan & Bill, Yarmouth, Maine
2024 Kia EV90 -
@aphillipsaphillips said:@TABNewbies and @tomtek Looking at lots of mods as we wrap up our first 2 week long road trip.
I felt is was easy but I am an electronics person for hobby and work.2009 Dutchman TQ - Sold
Are you trying to save parasitic battery drain or do you just want the lights on the stereo to go off? If it's the latter you can just read the manual to learn how to turn the light off.Bill&Suze said:I have the '24 T@B 400. The Jensen control panel has a perimeter bezel that I assume needs to be pried off to be able to remove the control unit to access wiring. The bezel edges are tight to the wall paneling and it doesn't budge a bit with fingernail pressure. I can't even get fingernails started under the edges. How are people safely removing it without marring the wall? Does the unit actually need to be removed from behind in the wall cavity? That would be quite a project to gain access.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
To prevent parasitic drain, which I confirmed by watching the VictronConnect app while the Jensen panel was powered, and then after pulling its fuse. There's an observable drop in battery amp output when power to the Jensen panel is cut.Marceline said:
Are you trying to save parasitic battery drain or do you just want the lights on the stereo to go off? If it's the latter you can just read the manual to learn how to turn the light off.Bill&Suze said:I have the '24 T@B 400. The Jensen control panel has a perimeter bezel that I assume needs to be pried off to be able to remove the control unit to access wiring. The bezel edges are tight to the wall paneling and it doesn't budge a bit with fingernail pressure. I can't even get fingernails started under the edges. How are people safely removing it without marring the wall? Does the unit actually need to be removed from behind in the wall cavity? That would be quite a project to gain access.Susan & Bill, Yarmouth, Maine
2024 Kia EV91
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
