Fuses
Apopejoy
Member Posts: 14
im a new T@Bber and a girl to boot. I would like to know conditions that would cause a fuse to blow, the most likely ones to go, how many should I have in reserve, where to find a listing for which fuses match what. Anyone?
Max S. Tumb@lweed, north Texas.
Several threads on fuses if you search...Here's one that's pretty good...
http://tab-rv.vanillaforums.com/discussion/163/fuse-inventory/p1
Thanks. I'll get the hang of searching.Max S. Tumb@lweed, north Texas.
Searching has gotten better here just recently so your timing is right :-)
Still not the best but the best place to start. -
Also, never apologize for being a girl! Checkout the Girl Camper podcast and the Sisters on the Fly group for some inspiration. And there are lots of girl t@bbers here and on the FB pages :-)John and Henrietta, Late 2016 T@B S Max in Western New York
I'm a "girl" as well (almost 60 but you get the point)- and never had a need to know anything about fuses until my T@B. This forum is a life-saver. I have a bunch of saved discussions just-in-case. Fuses being one of them.Apopejoy said:im a new T@Bber and a girl to boot. I would like to know conditions that would cause a fuse to blow, the most likely ones to go, how many should I have in reserve, where to find a listing for which fuses match what. Anyone?Amanda, Ft. Myers, FL Ag@tha 2017 T@B CS-S , TV: 2013 Chevy Equinoz LTZ
As a little comfort and to set the worry down a notch - As I recall, the only time I've blown fuses are when my brake and charging wires on the TV shorted out - that blew the inline battery fuses on both the TV and T@B. The other blew a blade fuse in the converter box but don't have a clue why. The ground fault tripped one time also.
Could have something to do with the fact that I'm rarely hooked up and running on solar/battery most of the time.
- 919 Introductions
