Ants
Wanderoo
Member Posts: 553
In a recent post, Belva mentioned the subject of ants. I recalled the ant discussion on the Little Guy Forum started by Michigan Mike, so I thought I would revisit the solution. Here's the thread from it. So, boric acid (Borax) and petroleum jelly are things I need to add to my T@B stash. X_X
http://littleguy.vanillaforums.com/discussion/comment/24450/#Comment_24450
Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B)
Thanks, Ladies.
There was an error rendering this rich post.
Yes, thanks, Sandra. I will investigate that one-tube solution. Sounds simple. Got to be prepared.
Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B) -
I definitely agree. Just ordered TERRO PreFilled Liquid Ant Killer II Baits 6 Pack T300 from Amazon. I used the Terro in the bottles with the little cardboard tabs several times over lots of years. The pre-filled packs look a whole lot neater.
Paula & Larry | 2015 T@B S M@XX "Serenity"| 2014 Subaru Outback | Maple Grove, MN -
I could not find it in stores in our area. I guess I need to order as you did Paula. I have been out of the ordering/buying for T@B scene for awhile. You finally get to the saturation point and just have to stop purchasing stuff because you have to put it somewhere. I will break down and order the TERRO.I do not like ANTS almost as much as I do not like SNAKES.
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
